Disables the examination of the DiffServ field in an IP packet.
port_list | Specifies a list of ports or slots and ports to which the parameters apply. |
all | Specifies that DiffServ examination should be disabled for all ports. |
Disabled.
The diffserv examination feature is disabled by default.
disable diffserv examination ports 5:3,5:5,6:6
